Results 1 to 9 of 9
  1. When i burn some dvdīs the last 5 minutes donīt work on the dvd.
    What can that be?
    i use
    Rip program = dvdshrink
    Burn Program = nero the lastest version
    Burner = pioneer 107d
    medie = dvd-r 4,7 gb 4-8x speed bulkpaq printable inkjet
    Thx for the time you use to help me
  2. Banned
    May 2003
    Massachusetts
    What can that be?
    That can be a million things, but 99.999999% of the time it's because you bought cheap media.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Either buy some better disks or make your DVD 10% smaller or so.
  4. Mod Neophyte redwudz's Avatar
    USA
    What ZippyP. said. Go into Shrink and set 'Custom' for disk size. The default is about 4.4G. Set it at 4.3 or even 4.2 and try a different brand of media.
    Jul 2003
    michigan
    quit whitting your dvds
    member since 1843
  6. Is that a cheap medie? i use?
  7. Is there a medie you will recommend?
  8. Banned
    May 2003
    Massachusetts
    Dear God. HOLD ME BACK PEOPLE DON'T LET ME GO APESHIT ON A NON-ENGLISH SPEAKER!
    Yes, it is utter crap media. The name "bulkpaq" should have been a gigantic tip-off. The words "bulk", "quality", "valu" or the letter "X" with a hyphen should NEVER appear in the name of the media. Also avoid any 'trendy' purposeful misspellings of words, like "paq" instead of "pack".
    Yeah, something good. Go to your local store and buy good media. Y'know, the kind that isn't $10 for 100. Where do you live? People from near you would be able to tell you what to recommend. In the USA you can zip over to your local Best Buy or CompUSA or Fry's and get some Fuji discs pretty cheap nowadays.
  9. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Taiyo Yuden is regarded as the best.
