Results 1 to 9 of 9
    Jun 2004
    Budd Lake, NJ
    OK, here is the problem. I cannot view many pictures and icons on some websties. I am using IE 6 and Firefox....happens on both. I recently installed SP2, but uninstalled, and did the same thing. I have another computer in my house, and it does not do this. So it is my PC. But i can't figure our why it happens with both programs....please help guys.....
    Mike :P
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Do you have flash installed?
    If not, then you need to install it.
  3. Banned
    Sep 2004
    Why did you uninstall SP2?
    You need it for the added security.
    Jun 2004
    Budd Lake, NJ
    I have SP2 installed, i just uninstalled it to see if that was the problem, but i don't think it was. And i do have Flash installed already. I think it may be in the SP2 settings or something, but i am totally lost....any other help?
    Mike
  5. Banned
    Sep 2004
    You could go into both IE and Firefox and see if Java is enabled.
    Australia
    I know this is basic but have you checked that images are enabled in the browsers?
    for IE:
    Tools -> Internet Options -> Advanced -> Show Pictures (must be ticked).
    for FireFox:
    Tools -> Options -> Web Features -> Load Images (must be ticked).
    Jun 2004
    Budd Lake, NJ
    Yes, it is checked, along with most of the other ones...... thanks. any other ideas?
    Mike
    Australia
    OK, are you using an Internet Accelerator? Some attempt to download all images in a batch first but many of the smaller images can get lost.
    Are the images being blocked or are they just not displaying when the page loads?
    If you click on page re-load do they appear? or if you right-click on the space where the image should be and select 'Show Picture' does it then get loaded?
  9. Member p_l's Avatar
    Montreal, Canada
    A similar problem plagued a computer I had to troubleshoot. Do you run ZoneAlarm? Try uninstalling it and doing a clean install (without keeping your previous settings) of the latest basic version (not the Pro version trial). That solved it for me, after trying many things.
