Hey everyone,
I ordered "Genuine" Ritek G04's and when i received my order i noticed the disks looked a bit different than my last 3 batches. The disks were plain shiny silver, but the bottom side seemed a lighter purple. Sure enough, when i popped the disk in my comp to check the media code....it came up as RitekG05. Haven't used G05's before, but i've heard they are not as faithful as G04's. I have a pioneer ao6u burner which i use to back up my movies and ps2 games. I went through 75 G04's without a single coaster. What does everyone think....should i make this an issue with the company I ordered from and demand the g04's, or are the g05's worth keeping??? Thanks in advance!!!![]()
Results 1 to 9 of 9
Depends entirely on what DVD recorder you have. G05 discs work fine on my Nec 3500, but not so great on my Liteon 1213@1633.
Go5 burned perfectly on my 105, so I don't think you will have any problem with your 106
Got the same thing with a couple of batches of Ridiscs - the dye looks the same as my other discs, but they show as G05 media code. No idea if they will burn at 8x, as I have a Pioneer A06. However, they have been as consistent with burns and compatibility as the previous discs. Possibly a mistake at the factory and the incorrect code was added?
You not the first to say this.. Even here in the UK i have seen a post saying that they ordered
Dvd dricpter shows then as GO5 yet they only burn at 4x....25pcs DVD-R Spindle x4 Speed (Orange Tango's) 1st Print, Certified Ritek Branded (G04 Dye)
Thread HereNot bothered by small problems...
Spend a night alone with a mosquito -
Hi Guys.
so whats the bottom line on these Ritek GO5's ? I have gotten used to the GO4's. Lately I noticed the GO5's on the shelves instead of the ol' GO4 faithfulls. Are they a complete replacement and upgrade, ie no more GO4's, and we have to start experimenting again ? Apart from the speed increase to 8x, are they as good and reliable as ol' faithfull ? -
RITEKG04 (not GO4) has been discontinued and has been replaced by RITEKM02. RITEKG05 is 8x-rated media and performs just as well as RITEKG04 at 4x on writers that support this media code.
Regards,
TerminalVeloCDCurrently own:
* ASUS CRW-5232AS 'QuieTrak'
* JLMS XJ-HD165H
* LiteON LTR-32123S, LTR-52327S, SOHR-5238S
* NEC ND-2500A@2510A, ND-3500A, ND-3520A
* Pioneer DVR-107D, DVR-108, DVR-109 -
I have been very pleased with the scans from the G05s. See the post below; the last scan was burned on an NEC 3500 at 8X.
https://www.videohelp.com/forum/viewtopic.php?t=237823&start=30Still a few bugs in the system...
I just ordered a magicjack and was wondering if anyone else used one
By johns0 in forum Off topicReplies: 9Last Post: 4th Oct 2010, 02:46 -
Microsoft ordered to stop selling Word!!!
By deadrats in forum ComputerReplies: 17Last Post: 19th Aug 2009, 18:27 -
Europe to get only full version of Win7E and no browser as ordered.
By edDV in forum ComputerReplies: 77Last Post: 29th Jul 2009, 22:41 -
Creating Ordered Chapters (Haali + MKV)
By PsyCLown in forum Video ConversionReplies: 3Last Post: 23rd Jan 2009, 16:52 -
Just ordered a Canon HD camcorder, did I make the right choice?
By rcguy1 in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2008, 09:27
