A buddie of mine gave me a HD transport stream, I'm having a little trouble playing it back.
The major problem is the audio, in that you can't hear or the audio plays back stutterer ? (is that a word)
I have played it with VLC but alas no audio also Mplayer
I have a dual g5 heaps of ram etc
I have played it back with audio on my pc with VLC but its just not pokey enough
anyone help
TIA
Does VLC or Mplayer tell you want audio format it is? Perhaps you could change it to something more suitable, like AC3.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
I have tried to export it to that using mpeg streamclip, but the file seems to be playing at x2 ?
Stream Transport
By Soixante in forum ComputerReplies: 4Last Post: 4th Apr 2014, 06:05 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 05:40 -
Playing ".pvr" transport stream files in MPC
By uart in forum Software PlayingReplies: 1Last Post: 7th Jul 2010, 19:26 -
Transport stream for XML?
By TrupsT in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jan 2009, 12:25 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 02:06
