I'm having problem in playing certain type of video file. whenever i play the files, the output was like this.
This is .dat file. i play it using Media Player Classic. and i install the K-lite codec v 2.27f
Find out what code it uses.
Uninstall the codec pack.
Downlod and install that codec.
Download and install the xvid codec.
Does it do that in any other player? -
if i'm using windows media player, it's OK. the problem exist only if i play the file using Media Player Classsic.
I've seen that problem before.
Luckily there was an updated version of Media Player Classic that addressed the issue.
What version are you using? -
i don't quite remember. but it's not the newest one. ok i'll try to change to the newest version first. i'll inform you later. thanx.
Video playback problem
By magiccastle in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 07:07 -
Video playback with audio problem.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2010, 06:50 -
Problem with 4:3 Video Playback
By pantyryder69 in forum Software PlayingReplies: 9Last Post: 9th Feb 2009, 18:31 -
MPG video playback problem
By mikemike85 in forum Software PlayingReplies: 1Last Post: 15th Jul 2008, 07:47 -
WMVHD Playback problem on a particular video
By huthmakerj in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 10th Jul 2007, 15:41
