Ok..I'm building a HTPC and I was wondering if anyone had any reccomendations for a video card that has a either a Composite or S-Video Out so I can display it on my TV..I won't be using this comp for High End Gaming. So, if possible, I would like to get the cheapest that I can get that has good quality.
Results 1 to 9 of 9
Radeon 9500 Pro. (Which is the same as a Radeon 9700) has S-Video out.
I love this card..dont still make them, though..So I'd recomend a 9700. Cheap, and still good.
:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
ok..thanks..any other suggestions?
Check out the "Capture Cards" link on the left under "Lists". The search page allows you to just check "Graphics cards" and not only capture cards. Lots of good information in there along with user reviews
This is what I'm using for the same application.
http://www.computergate.com/products/item.cfm?prodcd=AVGEMX4K
It has SVHS out and a composite adapter. Also DVI for future use. It's an 8X card. I use it with my projection setup and it works great. -
I've used my GeForce 4 MX440 with good results; you don't need an expensive card. I got mine for $30 (after rebates of course) around last christmas at Circuit City. It's the one made by Mad Dog, and it has VGA, S-Video, and DVI outputs. I would say you should just get an S-Video out because you will be hard pressed to find composite out on a popular graphics card, and you can always use an adapter to go from S-Video to Composite, which is what I do. Also, I have used the S-Video out on a Dell Laptop. The quality is pretty bad on that one and there is almost no color saturation to speak of, but that was on an older laptop: PIII 400.
I use an ATIAIW 7500 It has been discontinued but I hear that you can still find them new in the box pretty cheap(I haven't looked in awhile being as I already have one) It can be a troublesome card for some but I like it. My system is pretty weak but a new setup should be able to handle it no problem.
IS IT SUPPOSED TO SMOKE LIKE THAT? -
any really, all the newer vid cards come with s video out. maybe wanna pay a little more for dvi out for the future to.
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
I/O light flashing..help..need to connect HT to comp.
By techspark in forum Media Center PC / MediaCentersReplies: 7Last Post: 2nd Mar 2011, 13:30 -
How to connect internal USB 2.0 card reader in older PC?
By bevills1 in forum ComputerReplies: 24Last Post: 15th Apr 2009, 08:05 -
How do i connect audio on capture card?
By GLE3 in forum AudioReplies: 11Last Post: 9th Mar 2009, 23:06 -
Capturing screen image to video - using dedicated card - what software ?
By ullteppe in forum Video Streaming DownloadingReplies: 10Last Post: 12th Oct 2008, 11:34 -
I want to connect pc to older 28'' wide screen tv
By gibbsy07 in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 18:32
