I need a little help with this player... has been running fine for about a year and I just turned it on and it boots but will not see ANY DVDs.. tried about 25 different ones and they are all manufactured, not burned... I pulled power off of it for a while and no dice.. I opened it up and realized it is a PC based player in a carriage.... is there any way to pull it apart and check for issues or is this something that is worth doing?
I have seen online that they have a tendency to do this so any advice would be great... thanks in advance...
The 402 is unique in that it has no motherboard. The video components normally found on the motherboard are internal to the IDE loader. There are so many components in the drive it's bound to go bad. I had one and it did. Most likely the laser has gone bad. You cannot replace it with a DVD-ROM because it contains the motherboard. In short buy a new DVD player.
well thanks for the info....... I will be doing that this weekend... thanks -
I just messed with it a little more and it plays CDs, burned or manufactered, MP3 CDs but no DVDs...is that still an issue with the laser or something else...thanks for your patience....Originally Posted by wulf109
Is my DVD player dying?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Nov 2009, 01:20 -
How do you know when your DVD writer is dying?
By dqtus in forum DVD & Blu-ray WritersReplies: 12Last Post: 7th Oct 2008, 12:54 -
newbie archos 402 video question
By brucey2 in forum Portable VideoReplies: 0Last Post: 28th Dec 2007, 05:28 -
dying dvd burner??? help!!!
By cidth in forum DVD & Blu-ray WritersReplies: 6Last Post: 30th Jul 2007, 12:26 -
Why do my DVD players keep dying?
By BirdDaddie in forum DVD & Blu-ray PlayersReplies: 32Last Post: 31st May 2007, 05:29
