Without using Virtualdub's frameserving, is there other alternative?
I had successfully extract AC3 audio from the XVID (NTSCfilm) avi file using GoldWave, and isolate the video from the raw XVID.
And with this 2 new files, I generate a new MPEG (PAL) using ULEAD VideoStudio 6.0.
Unfortunately, the video clips contain non-english dialog, subtitles were needed. Frameserving using Virtualdub had not been succcessful with my old Celeron 466 processor, perhaps due to my inexperience with frameserving.
I had tried merging subtitles to avi prior to mpeg encoding, resulting distorted subtitle texts due to squashing of screen sizes during encoding.
Is there any tools to add subtitles directly to MPEG?
Suggest that you use Vobsub and Tmpgenc instead.
During the encoding of the video to mpeg, Vobsub should pop up and insert the subtitles into the mpeg. Burn the resulting mpeg with Nero. Please note that Tmpgenc chokes on AC3. Therefore encode just the video portion with Tmpgenc.
Search the guides for Vobsub.
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
How to Add subtitles to avi Xvid files !!!!
By prithvi in forum Newbie / General discussionsReplies: 11Last Post: 12th May 2011, 10:05 -
How to add Chapters, Subtitles and convert for itunes?
By TC1006 in forum Blu-ray RippingReplies: 1Last Post: 14th Jan 2009, 11:31 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
xvid.ac3-waf-avi convert problem?
By ptr866 in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
