  1. I can view what I am trying to capture, but when I try to capture it gives me an error that says:
    Cannot build capture graph!
    Anyone know what this means?
    it would help if you told us what capture tool, settings, to what format and what capture cards you are using.
  3. I get this too - all the time in Power VCRII v 2 and 3.
    It doesn't seem to matter what settings are used - it just drives you nuts
  4. i get it in TV view 5.4 no matter what settings are used..
    Nov 2001
    Cardio Sistemas Coml Indl Ltda
    I also got this and it seemed to be driver issue. Since you are using TV View 5.4 I can assume you have an CPH050/CPH060 card, usually sold by Phoebemicro, Askey and many others. These drivers are a piece of s**t.
    Try the driver found on http://sourceforge.net/projects/btwincap/
    You will need to get some tech specs of your capture device, specially the tuner brand/model.
    In my case (CPH060) my problems were completely solved.
