Hey guys.
I picked up the Logitech QuickCam Pro 4000, since I heard it's a top notch web cam out there. I only record SHORT videos (tops 5 minutes), therefore setting up my VHS-C cam, it takes way to long to setup, and then clean up just for a 5 minute video.
So I have this webcam, but I need a good software which will allow me to cature the video. The software it comes with DROPS a LOT of frames. I've tried using VirtualDub with some success. It doesn't drop anywhere near as many frames, but my problem is setting the program up. For compression I'm using DivX 5.2 Codec with it set to "SLOW on a single Pass". Frame rate is 29.97.
I mean, is that the best I can do? I would like to host the files on the web, so I need them to be sort of small in file size, but keep clarity. 20mb isn't big, but when I only recorded 1 minute, it is. Lol.
Any help is GREATLY appreciated. I've been going at this for 3 weeks now and can't figure it out. I figured I'd ask the pros.
Thanks in advance.
Jnick
If that camera is limited to USB 1.0 speeds, that may be a problem. I didn't see if it was USB 2.0, just listed as compatible. There is considerable difference between the speeds of the two interfaces. I don't know if there are USB 2.0 webcams out there, but that would be better.
The USB webcam I have only works well with the software that came with it. And it doesn't work that well. It's sitting on a shelf somewhere.
Another alternative, though you already have the camera, is a composite camera, similar to something like this: http://www.securitycameraworld.com/Security-Cameras/Mini-Board-Cameras/index.asp.
You would have to use a capture card, though. -
I don't have experience with that cam, but thinking back to the old days I would experiment with dropping either frame size or frame rate until capture was smooth and then increase until frame drops began and then back off again for margin of safety.Originally Posted by jnick
You will get superior results with a camcorder and capture card.
Look for a good webcam for chatting and capturing videos and photos
By coody in forum Capturing and VCRReplies: 4Last Post: 6th Apr 2010, 00:54 -
Capturing video @ 720p from a webcam
By StreakSRM in forum Capturing and VCRReplies: 2Last Post: 22nd Feb 2010, 12:55 -
Advice wanted on setting up Civic Webcam
By ahhaa in forum ComputerReplies: 3Last Post: 8th Jan 2010, 14:30 -
capturing msn webcam videos
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 8th Mar 2009, 23:08 -
Capturing via webcam
By VirTu3 in forum Capturing and VCRReplies: 0Last Post: 14th Nov 2008, 12:19
