i managed to convert 4 avi's using dvd2vcd,tmpengc,dvd author,now when i try to preview frames(of the same avi's) i get following message:
AVISOURCE couldn't locate a decompressor for fourcc divx (c:\program files\dvd2svcd\temp\preview-avs line 2)
all codecs are supported,as i have checked using avicodec-all avi's play on my pc
the video codecs i use are divx v5 and xvid mpeg-4 depending on wether avi is xvid or divx
the audio is mpeg layer - 3
i have just uninstalled the codecs and reinstalled them using k-lite codec pack,i have no other codecs installed
If you have already converted the files to dvd why do you want to preview the same avi's
just re-install the same codec's that you used to convert it to dvd in the first place
If MultiAVCHD is not supported, what is good tool to convert MKV to Bluray?
By Yanta in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 01:38 -
Convert Fujifilm S6500 ouput movie file Premiere supported format
By p_uriel in forum Video ConversionReplies: 6Last Post: 31st Jan 2008, 15:07 -
By p_uriel in forum EditingReplies: 1Last Post: 29th Jan 2008, 16:33 -
Figuring out why this AVI file crashes MPC & AVIcodec
By DRP in forum Software PlayingReplies: 14Last Post: 11th Nov 2007, 20:19 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 11:07
