Greetings all.
I am trying to back up my videos from the DV but it exceeds 2gb which is not readable by windows. And Virtual Dub just won't read it and so, how can I cut it down to lower than 2gb of data, so I can burn it up into a DVD? Because the DVD ISO format does not allow, and the DVD UDF format stops at a certain percentage during burning~
What version of windows are you using? There is a patch for avi >2gb that you could try depending upon what version of windows you are using. Most DVD authoring programs will create vob files <1gb to burn to the disk.
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 07:47 -
AVI Videos Cutting Out
By Blade of Tyshalle in forum Newbie / General discussionsReplies: 11Last Post: 8th Feb 2012, 13:49 -
MKVmerge Cutting videos
By Tylerr in forum EditingReplies: 1Last Post: 4th May 2011, 13:28 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
Which one is better? Shrink 4GB movie to 2GB MPG or 2GB Xvid?
By volam in forum Video ConversionReplies: 4Last Post: 13th Jun 2009, 02:20
