After converting my *srt file with srt2sup and authoring with rejig i played the resulting files in powerdvd and everything looked fine. I burnt them to dvd and when i played it back on my standalone some of the subtitles were running off the bottom of the screen. I read a post that stated that *srt files do not contain any positional info so just wondered if there was a way i could check whether the original positioning is going to be ok or if not, is there a way to adjust them, and if so by how much. Thanks in advance.
The positioning is done in srt2sup. You can specify x and y coordinates.
Srt subtitle converter
By fits79 in forum SubtitleReplies: 3Last Post: 12th Apr 2012, 04:38 -
[Question] How to insert an SRT (Subtitle) file into an AVI file?
By Greg14 in forum SubtitleReplies: 5Last Post: 30th May 2009, 04:54 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17 -
question about extracting subtitle (srt ) file from IDX/SUB files
By jimdagys in forum SubtitleReplies: 2Last Post: 13th Nov 2007, 13:26 -
Synchronizing a SRT/SUB subtitle to DVD
By stamstam999 in forum SubtitleReplies: 1Last Post: 16th May 2007, 16:08
