Im capturing stuff off my Sky+ box, most channels are fine but sometimes the captured avi plays back with the distorion like the attatched image shows and I don't know what causes it, I use IUVCR to capture but can't seem to correct the problem.
is it because it is a ntsc source, I think i recall having the same distortion when capturing videos off of my consoles.
TIA
Normal. It's called Interlacing. The image will look fine on a TV screen. Computer monitors display video differently from TV sets.
I thought that and burned it anyway and played it back on my dvd player but the problem was still there.
Originally Posted by Fourth_Stage
Had a look in the DIR but only the programs exe and a .dll files, what are good capture programs are there, i've tried virtualdub but that just hangs and crashes when i try to capture.
You could try VirtualVCR. It works well for me.
Also, if you can't change the field order during capture, you could change it when you encode it to mpeg.
Capturing problem
By Phoenix 37 in forum Capturing and VCRReplies: 4Last Post: 18th Jun 2011, 17:09 -
How Can I Correct This Collor-Problem? (Sample Inside)
By MrJacobAngle in forum RestorationReplies: 105Last Post: 9th Aug 2010, 11:17 -
DV capturing problem
By BMR in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Sep 2007, 16:19 -
Capturing Problem.
By rowie4life in forum Capturing and VCRReplies: 1Last Post: 20th Aug 2007, 08:33 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 15:09
