  1. Member monzie's Avatar
    Nov 2003
    The Village
    Anyone know if i can set up an auto-chapter routine with TDA with time intervals of around four or five mins... OR.... a set number of chapters spread over a movies length?
    Why? Because I cant be arsed to keep setting the chapter points manually!
    Is it possible?
    Dec 2002
    Bay Area, CA, USA
    Assumng TDA is TMPGEnc Dvd Author, yes you can. On the 'Chapter Cut Edit' screen, simply right-click in the chapter list column on the right, and select the item 'add chapters in specified intervals', then enter a value in minutes. Works great.
  3. Member monzie's Avatar
    Nov 2003
    The Village
    Cheers for that! HIGHLY APPRECIATED!! Have a drink on me....heres some virtual money < £1000 >.....spend it on virtual beer and a good virtual night out..oh and get a round in for your mates.
    I cant believe I've not seen it for so long (you just sort of get used to doing things 'your own' way...even if it does piss you off)...doh.!
    Learn summat new every day.
    Thanx
