  1. This is my Quistion
    can any one help me??
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You can always make it in Photoshop or whatever, then import as a .psd
  3. Thanks!
    But
    Could you please show me how ??
  4. Member racer-x's Avatar
    Mar 2003
    I make about 95% of my menus in Photoshop and/or Premiere. The only time I use DVD-Lab to make a menu, is when I want a quick one and don't care about quality.
    1) Make your menu in Photoshop (or equivelent). I make all buttons, text and subpicture, then save as menu.psd with all layers.
    2) In DVD-Lab, click on empty menu to activate it, then click Menu > Import PSD, navigate to the menu.psd you created and click open.
    It will load your menu preserving all your layers. You can then use the highlite selection tool to select your buttons.
    My advise to you, is to go to their tutorial page to get some ideas.
  5. Thank to you all guys
    but stell I cant make mask layer on photoshop
    but Thanks anyway
  6. Hey Guys!
    I did IT!
