Hi, i just downloaded moviefactory 2 and I'm having a problem getting it started. I started a new project but when I pick the movie I just shrink from dvdshrink it just shut the program off. Can anyone give me a solution to this. Thanx
Hello,
If your trying to burn the video_ts folder that dvdshrink made then just load it into your normal dvd software (like roxio, nero). Then go and select disc at once and drag and drop the video_ts folder as the main directory (ie d:\video_ts).
If you want to edit the vobs you need to either convert them to mpg or use an authoring program like tmpgenc dvd author that can read vob files.
Kevin
--by the way, I hope that's a legal copy or the trial version of the moviefactory your talking about--
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by yoda313
Ulead has the option of downloading the full software once you pay for it, as opposed to waiting for the CD to arrive by mail. I've used it myself for DVDMF and Video Studio.
