I tried TMPGEnc, but it said the is file not compatible. Is there anything else I can use? Thanks
Use the how to on left side to make it easy for yourself.
Can find how to go from RAD to Avi then to VCD compliant with your encoder. Also if you have QT pro can export into AVI. The TMPGENC how to will help you with the qt plug in or search the forum for more info.
Hope this helps you begin. -
Thanks! I didn't know you needed an extra plug-in for .mov files. I've made about 4 VCDs but they were all in .avi format. I have never done a .mov file before.
problems going from quicktime mac file to usable pc file
By pjcom in forum Video ConversionReplies: 11Last Post: 19th Apr 2010, 13:49 -
Quicktime file, 24p, need to send file with yousendit
By apollo1980 in forum Newbie / General discussionsReplies: 3Last Post: 21st Mar 2010, 20:44 -
encode a Keynote Quicktime movie to mpeg2 using ffmpegx possible?
By mkoehler in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2008, 09:16 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 18:19 -
No Audio after encode quicktime video in flash 8
By yunakokimama in forum MacReplies: 3Last Post: 11th Dec 2007, 19:07
