  1. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Greetings,
    I have been using NERO 5.5 for all DVD burns flawlessly for quite a while. I have my settings and defaults in such a way that compatiblity with players almost goes off the charts. Now the question..
    Just took advantage of the NEWEGG deal on an OPTOWRITE 8X DVD burner ( I already have a SONY external DRU500ULX) with Nero Express 6 OEM for 48 dollars (heck , thesoftware costs more than that)
    If I load this NERO, do I lose any functionality of the old ?? I mean, I don't want to break what isn't broken ....Help appreciated.....
  2. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    You shouldn't... just make sure you specify a different location from 5.5. Also you will no doubt find the OEM version will be a 'lite' version of the commercial release. Most often I find the LE, Lite or OEM versions of apps are toss away media due to their lack of functionality.
  3. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Okay great, so it will sort of co-exist as two different pieces of software ..I like that. WHEW....THANK YOU
