Hi guys I'm new. Looking for a way to put more than 80 mins of music onto a standard cdr. I know it can be done with movies and vcd's but is there a way of doing it for audio using tmpgenc template maybe?
No, CD-Audio is Linear PCM (Pulse Code Modulation) and cannot be compressed. Standard audio CD players would need special hardware to decompress it.
Otherwise, if you are just going to use your PC, download CDex and use it to make some MP3 or Vorbis files and store them as data on the CD.
Cobra
(Moved this to the Audio forum) -
Hello,
Or you could buy 90 or 99min cdr's. However, they are not 100% compatible. They should play in any computer drive but may or may not work in portable cd players/car cd players.
You would use the overburn option on your burning software. (there are warnings that it may damage your drive but I've done several times on these oversized discs without problems).
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Blu-ray .mkv files won't play both audio and video at the same time
By birdbrainblue in forum Software PlayingReplies: 2Last Post: 20th Jan 2012, 06:42 -
MKV, 1:37 long, audio always comes out 44 mins only..
By TheGlow in forum Video ConversionReplies: 6Last Post: 20th Apr 2009, 16:45 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 11:39 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 02:19 -
Creating a Subtitle File(.sub or .srt) With Just Text(no time sync yet)
By Digistras in forum SubtitleReplies: 3Last Post: 20th Dec 2007, 15:31
