I have movie in divx format with a frame size of 688X320 . I want to risize it to full scren divx format . what is the best ethod to do it ?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Hello,
You could resize it to halfd1 NTSC (352x480) or fulld1 (720x480). Your problem may be the 688, it's closer to full 720 but the 320 should be moved to 480 and that may be a problem viewing. Give it a test on a small clip from your main file. (you could use virtualdub to edit out a short scene to try the conversion). Good luck.
For an avi @ 4:3 (the file at the moment is 2.15:1) you would need to crop 130 pixels of each end of the picture making the resulting file 428 X 320......doesnt your AVI DVD player (or TV) have a zoom feature..it would be A LOT quicker (ie. no time at all)?
If not, then why not your use your pc and Zoomplayer to feed the picture to your TV through the TV out (DO NOT select FULL SCREEN on the TV out settings or you will lose the zooming)...again its involves zero time. -
You have two choices. Either crop and resize the picture to the correct aspect ratio for your TV (4:3?). In this case you will lose the sides of the picture. Or watch it in letterbox mode (as it currently is) and put up with the black bars top and bottom.
If you simply resize to 4:3 without cropping, everything will be in the wrong aspect ratio. People will look tall and thin etc. Its your choice.
How can I make SD look like HD?
By Nuke Shower in forum EditingReplies: 4Last Post: 29th Jul 2008, 13:53 -
anyone knows how to make this (example)
By pike8 in forum EditingReplies: 6Last Post: 18th Feb 2008, 16:21 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
Firmwares - want to make sure
By mn072065 in forum DVD & Blu-ray WritersReplies: 5Last Post: 13th May 2007, 19:53 -
need to make a menu
By m-man in forum Authoring (DVD)Replies: 2Last Post: 5th May 2007, 04:19
