Recently bought a NEC 2500A dvd burner.
It is recognized by the system - Windows 2000 pro.
But Dvd Shrink does not see it when it comes time to burn.
I am thinking there must be a driver that I need.
A Pioneer 105 has no problem.
The burning program is Nero.
Don't see this addressed in previous posts.
Any insight gratefully received.
Thanks,
Patwig
Results 1 to 9 of 9
What version of Nero? You may need to update it to the latest (there are free updates).
Try a different burning program or an updated version.
I didn't need to load any driver when I installed my NEC 2500 burner. -
Using Nero 5.5.
DVD Shrink 3.2.
The Nero was a cheap OEM, and as a stand-alone, has no DVD burning capabilities. So I was surprised by a successful burn when I first tried DVD Shrink with the Pioneer burner, and had come to expect more of same with any burner.
Yes, maybe now is the time to spring for the big bucks version of Nero.
I don't seem to be able to burn from DVD Decryptor.
Thanks,
p -
you should be able to update your version of nero 5.5 to the very last update of the5.5 series of nero and it will do dvd's.
Just bought an inexpensive oem version 5.5 on Ebay that sez it includes DVD burn.
We'll see.
Thanks,
p -
Nero that comes with a bought drive is not the same as buying Nero seperately.... while it will do everything the seperate version does it is coded to only work with the drive it came with.
Well anyway.
I now see that I can open Nero, and burn dvd that way. I coulda swore
that feature was not previously enabled.
I had been surprised that Dvd Shrink had originally found Nero and burned with it, since I didn't think I could use it for that.
Now I also see that I can burn ISO with Decryptor, from within Dvd Shrink.
So I have lots of options,
but wait.
I am using my original burner, which had no problems!
will hafta try out the nec, no?
thanks
DVD Shrink and IMG Burn
By tcory in forum DVD & Blu-ray WritersReplies: 10Last Post: 9th Jan 2011, 15:25 -
NEC DVD-RW +ND-4551A won't burn DVD-R DL
By Belfour in forum MediaReplies: 11Last Post: 5th Jan 2009, 05:32 -
DVD shrink is only encoding @ 2500 KB/s or so? Instead of the 12000KB/s?
By Denvers Dawgs in forum DVD RippingReplies: 6Last Post: 29th Jun 2008, 11:23 -
Any way to get DVD Shrink to burn faster then 2.5x?
By happydog500 in forum DVD RippingReplies: 1Last Post: 1st Oct 2007, 00:50 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
