Hi, I'm in possession of several very good quality Xvid files which won't play on my Philips DVP642 standalone player (the timer skips ahead in 10 or 20 second increments and never shows a picture). Seems to be an irregular problem since other Xvid files similarly encoded will sometimes play perfectly. Anyway, what tool can I use to convert these to DivX without them looking crappy? I've tried VirtualDub but am possibly using bad settings (I get a same-size output file but far inferior quality to the original Xvid file after using the DivX settings for VirtualDub found here: http://www.divx.com/divx/divxpro/guides/vdub.php).
Gspot tells me this: Xvid, 23.97fps. As I said, the quality, both audio and video, is great in either DivX player, WMP, or Nero Showtime, but they just won't play in the Philips. Any tips greatly appreciated. Thanks.
possibbly try burning them to a different media, i had that problem with 3 discs and i realized they were all the same brand, so i re-burned onto a different brand and they played fine.....worth a shot
Dr Divx.. if i ever have any trouble with xvid/divx files i just run it through drdivx and its fine..
i have that DVD player also and have one or two xvid files do that to me too..
Also make sure that you are closing the disk when done burning.. XVID file are very picky on that player.. if its not closed you will get all slorts of issues.. like no ff/rw or what ever..
GL
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 14:06 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43 -
Converting x264 to xvid for dvp642 standalone player
By ch4757 in forum Video ConversionReplies: 19Last Post: 23rd Jul 2007, 12:44
