Cinema Craft, Inc. is pleased to announce that a new version of CINEMA CRAFT(R) Encoder SP [CCE-SP] was released on September 30th, 2004. It contains great enhancements you have expected.
Enhancements
- Changes of GUI
- Automatic resolution conversion function on DVD/SVCD/VCD mode
- Automatic file size calculation
- 3:2 pulldown
- Automatic adding of encoding pass for more accurate inverse 3:2 pulldown
- De-interlacing function
- 4:1:1 -> 4:2:2 interpolation
- Allow adaptive quantization matrices switching for multi-pass VBR
- Provide an option of outputting bottom field first stream
- Y and C parameters for dithered quantization
- Automatic switching of block scan order
- Blanking function
- Quality improvement in fades on a static scene
- Adjustment for black frames
- Monochrome encoding mode
- Save/load template to/from file
- Reuse of the last modified parameter setting
- Save/load a chapter list
- Shut down the system when finished encoding
- Play sound when finished encoding
Cinema Craft, Inc. provides high performance MPEG-1/-2 encoders to high-end C&A houses, such as Hollywood Industry. Our flagship product CCE-Pro has brought forth many great DVD titles and made a name because of its performance and stable quality of output. It is a great honor for us to tell Deluxe Digital Studios, (http://www.bydeluxe.com/) a world leader in technology and media services for filmed and home entertainment, is one of our preferred users of CCE-Pro.
CCE-SP 2.70 is powered by the CCE encoding engine, and what is more, has advantages of off-line encoding system. We believe that CCE-SP 2.70 gives you a capability of producing Hollywood quality at affordable investment cost.
One of the enhancements 3:2 pulldown functionality will make a great impact on your workflow. It eliminates cost consuming telecine process and time consuming cadence correction of inverse 3:2 pulldown, and will allow small and medium facilities to go into the business.
The setting windows have renewed dramatically. Especially, newly added viewers to inverse 3:2 pulldown setting or chapter setting will improve the efficiency and accuracy of the setting.
CCE-SP has brought about many works on motion menus or bonus materials, and can be expected to make great works on A-references (main features). Some of major facilities have already achieved success with CCE-SP.
Results 1 to 16 of 16
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
lot of new stuff -- looks good
Now all we need is for someone to test it
Best Regards,
Sefy Levy,
why do you think i'm still in the office ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Cause you had too much coffee today ?
Best Regards,
Sefy Levy,
i am watching a 1 hour movie rendering -- of a mountain lake taken with fixed camera ...
i gull flies by at around the 40 minute mark ...
going to go get another coffee ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Didn't I say you had too much coffee ?
Good Luck with the Rendering, boy I sure miss being a ModeratorEmail me for faster replies!
Best Regards,
Sefy Levy,
$1995
Would have sounded nicer if it was 2004$ no ?
Best Regards,
Sefy Levy,
Sounds like a "big kid's toy" to me, at that price
Hmm.... It supports chapter lists? Sweet!
I wonder if it recognizes something along the lines of Spruce chapter lists. -
you please give me the download link...can't find it
hacking the Net using typewriter :D -
got only the link for this...
Cinema Craft Encoder SP
2.66.01.01 -> 2.67.00.27
Update version(Beta version)hacking the Net using typewriter :D -
oh its with visible light...sorry
Originally Posted by freestyler"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Fairuse 3D released...
By MothMan2 in forum DVD RippingReplies: 4Last Post: 18th Apr 2011, 20:08 -
Firefox 3.5 released
By minidv2dvd in forum ComputerReplies: 32Last Post: 13th Jul 2009, 19:07 -
Divx 7 released
By Peakr in forum Latest Video NewsReplies: 44Last Post: 2nd May 2009, 08:52 -
MacDVDBitrateParanoia v0.5 now released!!!
By bendermac in forum MacReplies: 12Last Post: 29th Apr 2008, 15:10 -
Ubuntu 7.10 released
By Baldrick in forum ComputerReplies: 10Last Post: 26th Oct 2007, 10:41
