  1. Hello,
    I'm trying to convert some home video AVIs to MPEG-1
    in order to make VCD. Everything works except that
    I have following problem - at the end of all files
    there is something wrong. Either the picture stops
    earlier (just freezing say 5 sec before the end of the
    clip), or the clip ends earlier (missing the clip
    end).
    My AVIs are NTSC and I'm using the "Video NTSC" option
    for the conversion. I played a lot with various settings,
    I'm still trying to find the problem. Maybe it's a
    framerate problem? But both the source and destination
    are NTSC?!
    Any ideas what could be wrong?
    Thanks,
    - Alex
  2. Avtanski,
    I get the same issue here! I noticed that when I made a file in NTSC with TMPGEnc Version 2.01, it would take the last few seconds off when I created the SVCD. Now, I am not sure where the truncation occurs, as when I make the exact same SVCD twice, the stops in two different places! I used CD/RW media on a Hitachi DVD.
    Just thought I would let you know you are not the only one!
