Looking to convert a number of avi files to DVD compliant mpg and author to disc - DVD. Example AVIcodec output is below. Iinput file is about 166MB and yet when I convert to mpg (using either Nero or TMPGEnc) the output file is approx 2GB. Hpw can I minimize size of mpg while maintaining quality of originaly avi. Suggestions for Nero or TMPGEnc would be appreciated. Thanks.
File : 166 MB (166 MB), duration: 0:22:21, type: AVI, 1 audio stream(s), quality: 48 %
Video : 145 MB, 913 Kbps, 25.0 fps, 544*416 (4:3), DX50 = DivXNetworks Divx v5, Supported
Audio : 20 MB, 127 Kbps, 44100 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
Don't use Nero.
Using TMPGEnc load the PAL DVD template, change the resolution to 352x576 (1/2 DVD) set the encoding method to CBR and set the bitrate to 2500 Kbps. You will get a file of around 500 MB which should look pretty close to the original. Using VBR you can get it 25% smaller but it will take twice as long to encode.
Good luck."Art is making something out of nothing and selling it." - Frank Zappa
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
MPG File Size and/or Timing Help
By GearBeer in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2009, 11:21 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 04:41 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
