Hello,
I just purchased a DVD burner (Pioneer DVR-A07U) and I am having troubles burning an MPEG file that's already on my computer to a DVD-R disk.
I have tried backing up an existing DVD I have using DVD Shrink and DVD Decryptor, and that works fine. But as for authoring an MPEG file, I can't get it to work. Here's what I've done:
So, I have an file called "My Animation.mpg" on my computer.
I downloaded IfoEdit, Imgtool Classic 0.9, and DVD Decryptor. I demultiplexed the video into an audio file (.mpa) and a video file (.mp2).
Afterwords, I authored it in IfoEdit using the .mpa and .mp2 files I demultiplexed previously. To see if it worked, I view the files IfoEdit created in the VIDEO_TS directory in DVD Shrink to see if the audio is in sync. However, the audio is not in sync with the video.
Even though the audio was not in sync with the video, I just wanted to try to burn it to the disk. So I tried to create an image of the DVD (F:/My Animation since VIDEO_TS is in the My Animation folder ) using Imgtool Classic 0.9.4, but the image does not create. It just stays at 0%.
So, what am I doing wrong? Is there another progress I have to go through?
Edit: I forgot to mention that the resolution of the video is 640 x 272 and not the standard resolution (which I believe is 740 x 480). So if I try to put the video file in DVD shrink, it says the resolution is incorrect. So how can I maintain the widescreen resolution of 640 x 272?
Hello,
I'm just wondering if anyone can help me because I'm still not sure what's wrong.
Thanks -
you need an authoring proggy like dvdlab or tmpgenc dvd author. i usually run my files through tmpgenc first to get everything to proper specs then use author proggy.
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Burn Already converted MPEG Movies To DVD
By killagoob in forum Newbie / General discussionsReplies: 1Last Post: 19th Apr 2008, 20:11
