I have two mpg files that I put into TMPGENC AUTHOR.
I burn the DVD, works and plays great.
Here's the problem:
I want to extract this VOB (which is now one file/vob containing two mpgs). Problem is, on playback,when it gets to the position of the 2nd mpg, the audio cuts out.
What is going on? and how can I copy this VOB intact?
though the file size is correct for two mpg's, a properties
evaluation of the VOB shows only the "time frame" of the
first mpg. What is TMPGENC AUTHOR doing when it
takes multiple mpg's and turns them into one vob?
Apparently, it does more than just joining them together.
Thanks in advance for any suggestions.
Hi vcdforme,
Are the MPGs (particularly the 2nd one) DVD compliant? Check with AVICodec on your MPGs to get the details, and compare against the specs under the "What Is DVD" link at the top left of the page...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
VOB to MPG - What to use?
By Thingy in forum Newbie / General discussionsReplies: 11Last Post: 24th Apr 2010, 16:18 -
VOB to MPG
By marbletravis in forum DVD RippingReplies: 2Last Post: 24th Apr 2008, 11:40 -
Problem with .VOB to .MPG
By SilverFalcon in forum Video ConversionReplies: 2Last Post: 30th Jul 2007, 13:27 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
