  1. i have an xvid clip and the audio starts going out of synch after about 10 mins or so. if i hit pause and then play on my phillips dvp642 then it is in sych but will slowly go out of synch.
    can someone help me fix my audio problem - i am new to encoding and stuff.
  2. use YAAI to sync your audio
    alternately I sometimes re-encode the xvid to DV using vegas or Virtualdub.
    drink up....the world's about to end
  3. thanks will try that
  4. Member Devanshu's Avatar
    May 2003
    Originally Posted by anubis13
    This is what I use...just extract the audio, and then encode it seprately with whatever you want to use.
