Hi.
I usually use a modified Daewoo 5800 for viewing Pal discs of all regions, but I had a need for another such unit, and even though the $39.99 price at radio Shack was a bit worrisome, after seeing many positive reviews among the negative ones on this forum, I thought I'd pick one up and give it a try.
Last night I hooked it up straight out of the box into my InFocus XL-1 digital projector, and popped in the Region 2 Dutch Pal release of Lars Von trier's Dogville.
I first used the region-changing hack previously mentioned in an earlier thread, and sure enough, the Cyberhome 300 recognized and played the disc. However, there was a lot of annoying stutter and flicker in the picture right from the get-go. It even appeared during the Interpol copyright warning.
When I say stutter and flicker, I mean the image jittered and skipped a bit, every 1 or 2 seconds. There was no static, just tiny fluctuations which made it unwatchable.
I took out the disc and tried it in my Daewoo 5800, and it played just fine, with only the every-once-in-about 10 minutes mild stutter or skip that I've come to expect from most hacked players under $100.
Has anyone had a similar experience with the Cyberhome 300? I have 30 days to take it back for refund or exchange, and I most definitely will do that, but I'm wondering if this is some sort of conflict with the Region hack or a digital projector like the InFocus that I am unaware of.
Then again, this could just be a lemon unit, and by swapping it out everything will be fine until the $40 player dies a natural death.
Any info or advice would be greatly appreciated.
- Jim
Results 1 to 1 of 1
"An intellectual carrot? The mind boggles!"
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 15:31 -
Region hack for Dunlop D-DVP6301 (rebranded Cyberhome)
By lothda in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Jun 2008, 06:05 -
Looking for replacement for Cyberhome CH-DVD 300
By inmate1577 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Dec 2007, 09:28 -
16:9 picture lower edge above the black border flickers on 4:3 TV
By Srivas in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 13:15
