I get that message when i try to load a captured mpeg into dvd author.. is there a way to patch this without re-encoding it?Code:*The video GOP is too long. The video GOP is too long. For a standard DVD it is necessary that the GOP fulfill the following condition: Max 36 fields (18 frames) (NTSC format only) Max 30 fields (15 frames) (PAL format only)
thankz
Operating System: Windows XP Pro
CPU: P4 2.53GHz
HDD: 80GB 7200RPM
RAM: 1024 DDR PC-2700
Video Card: ATi Radeon 9800 Pro (3D Prophet) 128MB DDR TV-Out
Motherboard: Asus P4S8X-X
DVD-ROM: Pioneer 16X Tray
CD-RW: Lite-on 52X
DVD-RW: Lite-on 4X -
Nope, if the GOP is too long, you have to re-encode (or re-capture with the correct settings if you still have the source)
whats a program that allows you to capture and select your bitrate as well was make the GOP not too long ?
CPU: P4 2.53GHz
HDD: 80GB 7200RPM
CD-RW: Lite-on 52X
Had that error message myself and allways chose to ignore it, plays fine on my dvd players - but others may be picky
I ignore this message.
What long GOPs may do is "hic up" during some scenes.
Of course, there are few picky standalones, but those are picky on almost anything!La Linea by Osvaldo Cavandoli
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 09:36 -
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 23:39 -
Long term storage of home video.
By kreg in forum Newbie / General discussionsReplies: 7Last Post: 6th Jul 2008, 04:50 -
ES Video and GOP timecode
By arturo83 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2007, 07:57 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40
