I have some mpeg1 movies when I authorize it it doesn't authorize the whole file?
When I join the mpegs together it authorizes the whole file but I lose the audio the last 3/4 of the move![]()
I use DVDLab to authorize. When I use mpeg2's in DVDLab it works fine, and I have used some mpeg1's in the past in DVDLab and it worked fine.
Is this because of the type of mpeg1?? or do I need to use a different authorizing program to do these movies??
Help![]()
Results 1 to 16 of 16
Why dont you try using TMPG's MPG tools and do a merge & cut?
Then try to author it in the program of your choice.
BTW
Authorizing is like giving permission, or your consent.
You're tryin to author a DVD, not authorize it.
Seth:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
OK author my DVD.
This is what I did but the last 3/4 of the movie had no audioWhy dont you try using TMPG's MPG tools and do a merge & cut? Then try to author it in the program of your choice. -
Does your MPG file have the complete audio? If not, then something happened during the encoding.
You said you joined the mpegs together before authoring. What tool did you use?Originally Posted by BCAESE
I used TMPGEnc Plus. After joining, the merged file worked fine. After authoring is when I had the problems explained above.You said you joined the mpegs together before authoring. What tool did you use?
are there any other good authoring programs you can recommend that will author my mpeg1??
Why join? If they are part 1 & part 2 of the same movie, just author them as parts if the same title. It will be authored to DVD as one uninterrupted video.
Joining is always tricky business, and should be avoided if threre's a possibility to achieve what you want without it.
/Mats -
I have tried authoring it separately and the file were cut short, about half. For example if both files were 60min each, the end result is authored files at 30min.
Are there any authoring programs that author mpeg1 with ease?? -
TMPGEnc DVD Author. Excellent!
/Mats -
Something's wrong with your source.
/Mats -
I've had problems like this before and the issue always seemed to be bad GOP time codes. Try using the rewrite time codes function in DVD-Lab on the movie clip that is causing issues.
Make a backup of it first because DVD-Lab will write directly to the file in question.
After you do that, remove the file from the assets and re-import the corrected one. See if that helps.
Need MPEG1 encoder
By Xpenguin17 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 5th Oct 2010, 11:16 -
can't play bd content after authorizing
By volam1 in forum Authoring (Blu-ray)Replies: 6Last Post: 7th Oct 2009, 12:38 -
DVD authorizing
By m baqar in forum Authoring (DVD)Replies: 14Last Post: 28th Mar 2008, 03:51 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 23:31 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 20:26
