Hi there,
can anyone tell me which is the best -in terms of quality- MP3 encoder for songs ?
Thx in advance.
Results 1 to 12 of 12
I use CDex, which rips and encodes my CDs all in one step and stuff, but I believe that this uses a codec called LAME or something... I encode using super high quality VBR, though... which this software lets you control like TMPGEnc lets you control your video encodes. My mp3s sound awesome like 320Kbps ones would, but since they are VBR, they only use 320KBps when needed, and after that, they go to as low as 34kbps during silence. Good space saver for those whole want nothing but quality.
irc.webmaster.com port 6667 #DDR -
LAME is the best for quality. And it's free.
TIbrO is right about VBR encoding - it's absolutely fabulous. LAME's settings are a little complicated, but if you bother to learn how to set it up it'll be worth it. -
What about Xing's AUDIOCATALYST. I have been using it for years and I LOVE IT.
Hi,
THE best MP3 encoder is LAME ! it's not as fast as most of the others, but that because LAME goes for quality, not speed.
Greetz,
pSyChO dAd
The difference between genius and insanity is only measured by success ! -
Educate yourself on MP3 encoding/ripping by going to:
http://www.r3mix.net
Great info there!
I use MusicMatch, it if free and it has a way to organize your music library.
Regards,
Jose -
I also use AudioCatalyst, Very easy to use, excelent quality
<img src="http://personal.lig.bellsouth.net/lig/c/h/chazb/Chaz.gif" border="2"> HTTP://WWW.GEOCITIES.COM/DIVXBYCHAZ -
IMHO any product using the LAME encoding is the best
for ease of use I go with AudioCatalyst if your ripping a whole cd but if your just converting a single wav file (which I do a lot being a musician) I go with dbPowerAmp which you can find in the 'tools' section - great 'right click - convert to' shell! very nice!!
MusicMatch is good but I think they use their own mp3 algo - and side by side it loses to LAME
Lame MP3 Encoder on Vista x64
By edt in forum Newbie / General discussionsReplies: 23Last Post: 31st Jul 2014, 15:33 -
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Does x264 encoder supprts AVI and mp3 format?
By Bonie81 in forum DVD RippingReplies: 6Last Post: 6th Apr 2010, 22:20 -
how to setup automkv to use lame mp3 encoder instead of fraunhofer
By deejay.2001 in forum Video ConversionReplies: 0Last Post: 1st Aug 2009, 06:42
