Whenever I convert a widescreen movie with tmpgenc and then burn it to dvd when playing the movie back the widescreen/letterbox display is fairly thin and the black bars top and bottom are much bigger than on any of my pre-burnt movies.
when creating the mpg in tmpgenc i choose full-screen (keep aspect ratio).
any ideas how to make the main picture bigger whilst maintaining the wide-screen aspect?
How are you setting up the parameters? If you use the wizard you should get the correct result.
If you are setting up manually the input needs to be set to an aspect ratio of 4:3, Video arrange of Full Screen and the output ratio must be set to 16:9.
You get the problem you describe if the input is set to 16:9 and the output is set to 4:3.
Also, maybe the input is not strictly 16:9 but has black-bars already in the video.
Why does converted HD to SD file show video as letterbox using Tmpgenc?
By Endoking01 in forum Newbie / General discussionsReplies: 9Last Post: 9th Jun 2010, 21:37 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 09:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 01:53 -
Letterbox/Pan-Scan - Encoding or authoring option?
By ecc in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2007, 01:40 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 13:54
