ScLive gives the option to capture to a single AVI file or several files using scene detect.
Are there any advantages/disadvantages to either of these options or is it just a matter of personal choice?
I guess if you plan to add transitions and the like it might be an advantage to capture to separate files. I personally find it easier to capture to one file and then use VirtualDubMod with AVISynth scripts to cut out commercials and split up captures into sections.
If in doubt, Google it. -
Thanks jimmalenko - I'm a total newbie and although I'd like to try every method, it's too time consuming. I have been capturing with a single file, but just wondered!
Could I ask you what writing program you use? -
writing ? do you mean burning ? encoding maybe ?
VirtualDubMod to edit via AVISynth scripts, TMPGEnc Plus to encode, TMPGEnc DVD Author to author and Nero to burn for me.If in doubt, Google it. -
Thanks again jimmalenko - I tried Nero but have had a few problems . I think I need to update to version 6
The other way to go is if using TMPGEnc DVD Author, use its inbuilt burning program to either burn directly or create an ISO and then burn that with DVDDecrypter.
Thanks - I did try TMPGEnc DVD Author, but keep getting a message that an error has been generated and a log will be written and then it hangs. Don't know what the error is so am going to try DVDDecryptor. Your help is appreciated.
avi to dvd after scenalyzer capture
By robroth in forum Authoring (DVD)Replies: 7Last Post: 9th Jan 2012, 18:23 -
Scenalyzer, optical scene detection
By BTB554 in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2011, 00:48 -
8mm camcorder capture to dvd via EasyCap + Ulead - basic query
By deaglan1 in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 16:05 -
Scenalyzer and Vista
By bobogs in forum Capturing and VCRReplies: 3Last Post: 16th Jul 2007, 22:03 -
Scenalyzer Live 4.0
By Jone.T in forum EditingReplies: 1Last Post: 7th May 2007, 09:38
