hi.i have captured some satellite tv using virtualvcr and using a winfast vc100.i captured at the highest reso.the outputed avi was excellent.i used virtual dub for the wav,then used tmpgenc later to encode to mpeg2 dvd pal.settings was---constant bitrate(6800k/s).,interlaced,bottom field first(field b),audio 192k/s 48000.. these were the settings then i used dvd author later. the problem i have is when after burning in nero on riteks the dvd appears shakey/bluury in the moving scenes.its as if the dvd player is struggling to playit.i tried in 2 standalone players and its the same.if i use my own dvd rom and run through power dvd the disc plays fine.any help with this please? thanks ian
Originally Posted by ianskill
Are you certain that the source is BFF? I thought BFF was reserved primariliy by DV codecs. If the source is TFF and you encode with BFF, it will certainly cause "strange" behaviour in motion scenes.
T -
i think you are spot on and expected this reply.i did a bit more research after this post and realised that i should have selected top field first.i re encoded part the film and now appears fine.might experiment now with an alternative capture program for direct mpeg.a captured avi took 45 gig at 80 min using huffyuv codec.thanks for reply. ian
Captured VHS to DVD didn't turn out so well...
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 24th Dec 2010, 08:20 -
Authoring captured 16:9 DVD to display correctly
By Richard_G in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2009, 09:03 -
Shakey images in LCD screen of Sony Handycam
By J Lynn in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2009, 19:48 -
Captured HD Video - want to put on DVD in HD quality
By Coroner in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2008, 16:32 -
Fastest from captured video to dvd?
By larrym in forum Newbie / General discussionsReplies: 35Last Post: 14th Jul 2008, 08:03
