Hello! I have a problem and I need your help people. I am currently making a Mr.Bean video which is about 3 hours. When i play all the videos they are good quality on full screen. So I put all the vids together in adobe premiere. What export setting should I use( Frame Size, Audio settings, etc.). I want the quality to be good but i can afford to gain SOME size to make it like that. So i was thinking about these 2 options:
1. Export it in Avi format then use virtualdub and make it iin divx.
2. Export it in mpeg or avi then use windows media player encoder and make it a .wmv file.
Which 1 is better and for EACH what should i make the frame size???????
Thanks in advance!
Results 1 to 1 of 1
