I have a copy of True Lies here from a while back, that I had up at my cottage. Anyways, I used my computer to play DVD's up there, and it worked just fine, but for some reason, this DVD won't play in my DVD player...
I tried on my home computer, and it works fine... Anyone have any idea what's wrong...?
What kind of disk what the backup on? +r or -r ? Your home dvd player might not play one or the other.
Imagination is More Important Than Knowledge -
Sounds like your dvd player is not compatible with the type of disk you are bufning the film on to
or
Your dvd player can not play dvdr's -
what did you use to create the backup? It may be the software that was used to create the backup didnt do a very good job
MOV files won't play audio - RAM problem?
By MJW01 in forum AudioReplies: 1Last Post: 18th Nov 2011, 05:26 -
DVD+R won't play, have I bought the wrong format? - New post/problem 15/12
By yultie in forum MediaReplies: 20Last Post: 17th Dec 2010, 13:59 -
Blu-ray backup won't play in PS3
By DGenerateKane in forum Blu-ray RippingReplies: 40Last Post: 27th May 2010, 00:57 -
FLV converting problem: video won't play
By dombi in forum ffmpegX general discussionReplies: 0Last Post: 1st Apr 2009, 02:51 -
Problem DVD won't play with my DVD player
By maggot6sic6 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 01:11
