Results 1 to 13 of 13
  1. this is my problem with vob2audio error: Ligos splitter seems to miss an auido stream! use the audio vob option in smart ripper or use vob tools to delete the first one how do i use the audio vob?
  2. got to stream processing then click on the stream process and go to the side and select demux to another vob and thats it now go rip the dvd and you will have the extra vob with all the audio streams
  3. waddya ya my fellow filipino brutha help me out thanks homie
  4. FlipMC are you following my guide on the side????????
  5. yea im following it
  6. hey pinoy u go on irc?
  7. ok heres what the error says when i load the vts_01_([0x80]_Audio).lst with vob2audio coulnt find the ifo-file! no verbose mode for stream selection! then it says the same error Ligos splitter seems to miss an auido stream! use the audio vob option in smart ripper or use vob tools to delete the first one
  8. the last resort is to just rip the ac3 file from the dvd and downsaple with azid..to get the ac3 file do the same on top but this time select only the audio stream you want and on the rite select demux to ac3 file okay.....and no i dont go on irc i dont go on any chat rooms only instant message
  9. and oh yea here is the azid guide for the gui:
    http://www.doom9.org/azid-guide.htm
    and you can download azid and its gui at http://www.doom9.net
  10. pinoy can i have ur aim sn s itlle be easier to conatact u
  11. FlipMC i dont have aim all i have is ICQ and MSN MESSANGER
  12. whats ur msn messanger sn
  13. just type my emailadress go to my info and get it
    jud_o@hotmail.com
