I have/had but then switched from XP media centre to xp pro
the one thing I liked about it was the ability to watch T.V. record it and search a guide and set it up as a vcr to record one show or whole series etc.. But the main problem with it is it records in dvr-ms format. Which is hard to work with after the fact.(I have tried the graph)and the file size is large.Is there a program with these kind of features that records in say avi or mpg something in which I can easily shrink down to divxx and keep several episodes on one cd/dvd. I read the doom9 guide on virtual vcr but that seems very complex. Hence why I liked media centre minus the file format
thank you kindly Mapleleefs
You can also set the Media Center to record in 'Good' mode instead of 'Best' which will record the shows at a smaller size so you can fit more onto a dvd disc.
Panasonic E-85 & Panasonic E-55 dvd recorders
Gateway 510XL with Media Center 2004
External Iomega DVD-Superdrive (writes DVD-Ram)
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20
