    Jul 2001
    I ripped a DVD to my HD and was to remove the comming attractions before I make a new DVD copy. How can I do this.
    BM
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi BMzx,
    Look into either VOBBlanker or TitleSetBlanker. I've used the former and it does a good job.
    Hope that helps...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    i know many peple complain that you need to pay for this programe but give DVDREMAKE a try. it will do this very easily and will also let you change previews or other footage for your own footage. you can totally change how a dvd will play almost as if you have authored the dvd yourself from scratch. well wporth it
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    awwwwww but you need to pay for DVDRemake
    TItleSetBlanker or VOBBlanker can do the job perfectly well for the right price (free ). This will retain fully functional menus while removing the annoyances like trailers. If you wish to do movie only, you may want to look at DVDShrink in re-author mode.
    If in doubt, Google it.
  5. Member daamon's Avatar
    Melbourne, Oz
    Yes, I forgot to mention that one.
    P.S. stackner - Where's your "shark" avatar gone?
    Carpe diem.
    Jan 2003
    Deep South - La
    Is there an alternative to DVDRemake? That will do all that dvdremake will do, but is made by someone else? I may have a problem with dvdremake for some of the videos I am working with.
    Thanks,
    pcexpress-guy
  7. pcexpress-guy - please don't threadjack, start your own. I know it's actually on-topic of a sort, but not so fair on the original author of this thread.
    Thanks!
