I have a linksys wireless router, and I no longer need the use to be wireless, so can I just remove the antennas to stop sending the wireless frequency. I'm just going to use it as a wired router....
What We Do In Life, Echoes In Eternity....
No, that won't do it, it may dilute the signal, but it's still enabled. Go into your router setup and click on the 'Wireless' tab. On the drop down box that says 'Wireless Network Mode' choose Disabled, then click 'Save Settings.'
Nothing can stop me now, 'cause I don't care anymore. -
Will this disabling still allow internet flow through the hardwired network? or stop all traffic?
What We Do In Life, Echoes In Eternity.... -
Should stop wireless only. Also I think this is the router with the Linux based firmware. If I'm not mistaken there are all sorts of really advanced router function you can flash into that thing.
Edit: cleared up the first scentence, it said exactly what I didn't mean. -
Yea I've heard of the flash stuff, just haven't had the time to look into the specifics/features yet.....
VPN and Static Routing with Linksys router
By CogoSWSDS in forum ComputerReplies: 0Last Post: 30th Aug 2009, 00:33 -
How Can I Set-Up the Linksys Wireless Router??
By Frank-0-Video in forum ComputerReplies: 9Last Post: 27th Feb 2009, 16:18 -
Linksys WRT54GX4 router problem
By SIRCOOKS in forum ComputerReplies: 9Last Post: 19th Feb 2008, 11:40 -
Problwm with connecting to ftp using linksys router
By Wizard23 in forum ComputerReplies: 9Last Post: 3rd Nov 2007, 01:42 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56
