While remuxing a MPEG-1 file using the MPEG Tools in TMPEGenc, I got the following message: "8 packets had buffer underflows. Problems may occur when playing this MPEG file". Does anyone know what this error code means? The file seems to play and FF/RW fine in WMP 7, but I have not burned it to VCD yet. Is this error message something I have to worry about?
Make sure you use MPEG-1 VCD from the drop down box when remuxing. I used to get that error when muxing using MPEG-1. The video did play fine but when I went to burn it Nero had to reencode the entire thing which took forever. As to what the error means I have to idea. I search high and low for an answer but found alot of people asking the same question and no answer.
Decoding and interpreting PSI sections split across TS packets
By Tuxdude in forum ProgrammingReplies: 0Last Post: 19th Sep 2011, 22:30 -
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 09:04 -
Warning : NAV Packets are not detected in video.mpg. Please demultiples
By anindyanuri in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2008, 21:38 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 00:38
