If you're using Ritek DL's then you would need Herrie's firmware (herrie.org). Same goes to NEC ND-3500A... I'm not sure if the NEC has already published the official firmware for Ritek DL's? But that Herrie firmware should ok... also use the latest version of NeroOriginally Posted by hunghuynh
Results 31 to 38 of 38
[offtopic]
I just got the 4X 4.85GB DVD-R discs 8) Yes you read just right... 4.85 GB...
[/offtopic] -
@Adder_78, Cool I'll give a go when I aquire some more DL discs. I've been reading about the Layer Break on alot of other forums. Someone did suggest that removing the Layer Break info first and then burning with Nero. This would make sense if burnt with CopyToDVD as apparently CTD updates the IFO file with the new LB position. However I am hesitant to use CTD again as the result was unplayable. I'm not sure but I was under the impression Nero's current version didn't add any LB info to the IFO file, so removing the LB beforehand and burning with Nero would produce a disc without any LB info in the IFO, would this disc even play properly? I have no doubt it would play on my computer but for standalones that's a different question. This was posted on another forum:
Here is the response from our Engineers:
"Question:
I'm curious if nero yet supports adding the layer break flag into ifos when burning dual layer. Ie seamless layer break support. Anybody know?
Answer:
Nero sets the layerbreak in images bigger than 4.7GB, in case they are below no layerbreak is set. This is the behaviour up from the next Nero version (> 6.3.1.26). Currently no layerbreak is set in the image.
Question:
Or the opposite: paying attention to any existing layer break flag(s) and making the physical layer break match the position of one of them.
Answer:
Currently this isn't done so far in Nero. Usually the layerbreak is removed
by most riping tools, only in case you have an unprotected DVD and copy the content to HD using the Explorer then the layerbreak in the IFO file is kept.
However we have created a Bug Entry to check for the layerbreak in the IFO file. This will be addressed in a future release."
So I take it, the next release might be quite useful.
P.S. @Adder_78 you know you want to send me some of those 4.85GB discand some DL disc if you want
P.S. @Adder_78 you know you want to send me some of those 4.85GB disc and some DL disc if you want
by most riping tools, only in case you have an unprotected DVD and copy the content to HD using the Explorer then the layerbreak in the IFO file is kept. -
Usually the layerbreak is removed by most riping tools, only in case you have an unprotected DVD and copy the content to HD using the Explorer then the layerbreak in the IFO file is kept.
and that definetly doesn't do that). If you wanted to remove the Layer Break info, you could use IFOEdit or use DVD Shrink or even Nero Recode.
[dwisniski,
What version of firmware do you have on your drive and what version of decryptor did you use?
I have a 108 and my attempt at iso rip and then burn failed. It wwrote everyhting, and said that it was finished, but it had to close the session. After 45 minutes of closing the session, still no movement. When I cancelled, I had a perfectly good $10 coaster
So far the only method that worked for me, was rip the files and then burn in Nero dvd-video mode.
Thanks,
kosekjm
quote]
Kosekjm, sorry to reply so late, I am using 1.10 firmware on the DVR-108, and the latest version of DVD Decrypter (downloaded from doom9.net). I haven't backed up any DVD's since Gladiator (DL's too expensive still), but the first burn went flawless, I was surprised how easy the process went.[/quote]
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 13:20 -
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 08:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 00:50 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 09:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 08:38
