I am fairly new at linux and want to install some new apps. I downloaded avidemux from:
ftp://ftp.nerim.net/debian-marillat/dists/stable/main/binary-i386
I then opened the package in kpackage, and clicked install it gave me this error:
<noppix/avidemux_0.9-woody0.0_i386.deb' ;echo RESULT=$?
dpkg: dpkg ???????????????????: ????????????????
RESULT=2
What can I do to install packages in linux? I am using Knoppix distro. Thanks
Eh, its a program for the Debian distribution of Linux, not the Knoppix.
Any program you install has to be compatible with your distribution of Linux. -
I thought Knoppix was based on Debian. If not Debian, what is it based on?Eh, its a program for the Debian distribution of Linux, not the Knoppix.
not sure. but i don't think so. i'm pretty sure it is its own thing.
i might be wrong. but it doesn't say anything about that on the knoppix website. -
Knoppix is based on Debian, but because of its heavy modifications you'll have to jump through some hoops to install packages. It's all documented so do a little reading before you try again. Don't mess around with kpackage, it's junk. Just "dpkg -i file.deb" as root. If it can't be installed you'll probably get an actual error message telling you why.
A man without a woman is like a statue without pigeons. -
let me give that a try and get back to you. Thanks.Knoppix is based on Debian, but because of its heavy modifications you'll have to jump through some hoops to install packages. It's all documented so do a little reading before you try again. Don't mess around with kpackage, it's junk. Just "dpkg -i file.deb" as root. If it can't be installed you'll probably get an actual error message telling you why.
I did this in console:Just "dpkg -i file.deb" as root.
su
dpkg -i mplayer.deb
It gave me an error, which for some reason was in Chinese or Japanese, even though my regional settings are English. Because if this I can't tell you what the error message is. as far as the "file.deb", don't I have to specify the folder by cd ing or something? Since this didn't work, do you have any other suggestions? I already tried apt-get install mplayer, which gave me another long error in Chinese. -
Replace "file.deb" with the path to your deb file. If it's in the current working directory then you just need a filename, if it's somewhere else you need to give it a path. This matter of pathnames is pretty basic UNIX stuff, you should probably spend some quality time with a beginners' guide.
As for your other problem, learn Chinese? I'm not sure what to tell you on that, I never used Knoppix for anything but a temporary system when I didn't have a hard drive in one machine.A man without a woman is like a statue without pigeons.
How to build Hybrid Fontend Debian installer package?
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 5th Nov 2011, 11:28 -
Media Center packages
By nlaak in forum Software PlayingReplies: 3Last Post: 14th May 2009, 14:42 -
Converting video of any format to MOV or MP4 Linux/Debian
By lordshadow in forum Newbie / General discussionsReplies: 11Last Post: 31st Aug 2008, 10:35 -
mencoder and mplayer packages
By mattr in forum ffmpegX general discussionReplies: 1Last Post: 30th Dec 2007, 08:05 -
dvd to psp fails on debian with ffmpeg can someone see what I'm doing wrong
By oswaldkelso in forum ffmpegX general discussionReplies: 0Last Post: 26th Jul 2007, 07:57
