ok i have a compaq p4 1.5ghz 256mb ram and i just put in a wintv pci capture card. i tried to capture video from its software but it captures avi format and takes like 700mb per minute and thats way too much. so i downloaded nanodvr and v-dub from the tools menu for capturing and none of them work right. nanoDVR says it cant process the video format and there is no audio. virtual dub sometimes doesnt work and when it does i dont know what settings to put to make a vcd mpeg file. and now after installing nanodvr and v-dub, my old capture program that came with the card wont work!
please help me!!!!!
oh and i forgot to add that my computer now has become very unstable and i have to restart it every 5 mins (honestly!). it always is locking up and it never did it before i installed the capturing programs
thats what u get when u buy a compaq
compaq persario = comcrap pretty-sorry-yo
lol
sitlet,
START ALL OVER!
I just came back from the store and doing some other chores. I'm finally
here, in one spot. I came back with a WinTV GO card (to replace my very
old Hauppage wintv pci card from 96)
I'm probably gonna do the same thing. START FROM SCRATCH TOO!
I have some many capture card drivers in my system, and my sys is prob
going bonkers with me. It's to the point that whenever I start VD, or
AVI_IO, etc., that I get so many error messages/dialogue boxes popping
up at me.
You should to and do a clean reg process. Hauppage has a couple of apps
for you. Try those out. Let me see. I think I remember where they are:
* There main Support page
* Frequently asked questions (FAQ)
* InstallationUpdatesUTILities - 95-98-ME - 2000-NT
* more
Well, that's about all I can offer you.
Hope this helps, or maybe someelse can offer more.
Good luck!
Sample
<font size=-1>[ This Message was edited by: vhelp on 2001-11-24 19:43:09 ]</font> -
ok thanks! thats what im gonna have to do. i just bought this computer about a month ago so there is not much on it. i'll make a backup and then reformat the hard drive. i probably just put too much on at one time.
and yes i agree: compaqs are pretty sorry yo. my las computer was a compaq i bought in 99 and had so many problems and i dont even know why i bought another.
thanks again!
What to keep in mind so that the dvd will play on all players?
By Srivas in forum Authoring (DVD)Replies: 8Last Post: 19th Dec 2011, 05:20 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 14:39 -
Hey, if you don't mind me asking, how do you upload more than 10 min in YT?
By Vlenbo in forum Video Streaming DownloadingReplies: 8Last Post: 25th Dec 2008, 16:21 -
I think I made my mind up about what Camera im Getting... check it out
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 30th Dec 2007, 23:37 -
Intresting project on my mind!
By fLYtRap in forum ComputerReplies: 6Last Post: 3rd Jun 2007, 08:30
