So here is the situation in short. I downloaded a movie that is in two files .rar. I unpacked them and under properties it says they are DivX codec with AC-3 audio. I merged the two files using Virtualdub. Then, I extracted the audio using Virtualdub. Then I tried to encode the AVI and MPEG files using TMPGEnc XPress. After just a few seconds of the program running, I get this message.
VFAPIFrame server.exe
Error Signature
App Name: vfapiframeserver.exe
App Ver: 1.0.0.8
Mod Name: divxdec.ax
Mod Ver: 5.1.1.1031
Offset: 00046773
Invalid Sample Format
(error code 0x80048002)
Can someone please tell me what caused this and how to fix it? I did a search and couldn't find anything that was similar to my situation. Also, please don't tell me to use The FilmMachine. I tried to download that program and for some reason it won't work on my PC. Thanks in advance to everyone for all the help with this matter. If there is any other information that you need, please just let me know.
If I say or post something stupid, please excuse me because I am a computer dummy. - Kaizen10366
I think when you use a template to convert click on video only to convert, works for me
It may have AC3 VBR audio, which can be a problem for TMPGEnc. I would strip out the audio and convert to WAV, then select the video and the new WAV file in TMPGEnc. I also wouldn't merge them in Virtualdub, but take the two MPEG-2 encoded files and add them both to TMPGEnc DVD Author and they would play one after the other, seamlessly. This can help prevent audio sync problems with merging.
Denon DBP-1611UD multi-region DVD player giving puzzling message onscreen
By outfoxed in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Aug 2011, 03:39 -
Bizarre error using TMPGEnc 4.0 Xpress?
By the colonel in forum Video ConversionReplies: 1Last Post: 29th May 2010, 20:30 -
Tmpgenc Xpress 4 stream reading error
By WinSpecToR in forum Video ConversionReplies: 8Last Post: 16th Oct 2008, 07:50 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28
