I used VirtualDub to merge two AVI files, both about 700 MB each in size. I first opened the first one, then appended the second one, then saved the whole file as AVI. To my shock, the window showed a projected size of 117 GB (kid you not). The save was interrupted after 4 GB when the drive ran out of space. There is something very wrong here, or am I not picking the right save option?
After Appending ensure the option <Direct Stream Copy> is set in both VIDEO and AUDIO tabs....then go back to FILE and select Save As AVI (Save As if using VDM)....that file size of yours sounds like a default Video codec was set and you was NOT using Direct Stream Copy but <FUll Processing Mode>.
By the way why are you joining the AVI's? -
Hi namsilat - monzie has already answered the first part. As for the 4Gb file limit, that's most likely because your file system is FAT32 and you need it to be NTFS. Or, indeed, you do only have 4Gb of disk space free...Originally Posted by namsilat
What operating system are you working with? Update your profile with the info (Computer Information).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Ok profile updated.
I have two AVI files that should take about 3 CD-R80, so I want to join them, convert/encode, then split into 3.
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
Merging avi files with subtitle and aac soundtrack
By kurian in forum Video ConversionReplies: 5Last Post: 31st Jan 2011, 02:52 -
Problem in merging splitted AVI files of a movie into one.
By nick2712 in forum Newbie / General discussionsReplies: 8Last Post: 2nd Oct 2010, 14:20 -
Quality problems after merging two .avi files
By Metallo in forum EditingReplies: 14Last Post: 13th Aug 2008, 09:50 -
Problems with merging to avi files
By mingul in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
