I have an avi in English but it also contains someone giving a commentary throughout (which is what I want to remove). Is there any program that would easily remove the commentary and leave just the English?
I tried aviwav33 but it only decompressed the commentary. Can anyone give any suggestions?
Thanks in advance!
Try Virual Dub mod, select a track, save it as a wave, select the remaining track, save it as a wave.
Hello. -
I'm not sure exactly how the avi/divx file holds their audio, but i'm guessing all of the audio is on 1 track. If this is the case you won't be able to remove the commentary without also removing anything in that frequency range on the entire audio track..
If the files DO have the capability of having seperate audio tracks then ignore the above post :P -
Is the commentary intermingled with the audio or is it coming from just one channel (either Left or Right)?
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
Program switches audio track priority of dual-audio assets
By PBear in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 16th Nov 2007, 19:36
