When I try to change an MKV to AVI, my audio gets out of sync. How do I fix that? The MKV has MP3 audio. Here's what I did.
1. Demux MP3 audio using AVI-Mux (could not demux in Vdub)
2. Open MKV in Vdubmod
3. Stream List, Disable all, Add MP3 to the top of list
4. Yes for header alert thing
5. Video, Direct Stream Copy
6. Save as AVI
The result? The human voices come way before their mouths move. It's the same when I play it in Windows Media Player. Any help or method is much appreciated!![]()
4. will make it out of sync. it even says that.
try instead use virtualdub-mp3-freeze. open the avi(demultiplex the video from mkv) and add the mp3 and save as a new divx.
if that doesn't work try reconvert the mp3. -
you can also use mkvextractgui included mkvtoolnix to demultiplex mkv.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
MKV2AVI best configuration
By katalogas in forum Video ConversionReplies: 0Last Post: 15th Jun 2010, 05:38 -
mkv2avi problem
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 7th Jan 2010, 05:23 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
